| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Import |
| Date Logged & Current Version | Feb. 2018 11.02.00.10 |
How to reset the PCF translator PCFin.MAP used inside of AutoPIPE?
Step #1: Using PCF translator 1.00.00.69 or higher (installed with AutoPIPE 11.02.00.10), open the translator dialog.
Step #2:
Using AutoPIPE 12.03. or higher: Select File> Preferences>
or
Using AutoPIPE 11.02. - 12.02: Select Tools> Preferences>
Step #3: When the dialog appears press the "Reset Defaults" button
Step #4: press OK to continue, and now process a PCF file using the default PCFin.map settings
PCF Translator FAQ & troubleshooting
