Applies To | |||
Product(s): | eB Web | ||
Version(s): | 15.xx, 16.X.X | ||
Environment: | N/A | ||
Area: | Documents | ||
Subarea: | N/A | ||
Original Author: | Deepti Patil, Bentley Technical Support Group | ||
eB objects can be compared with the similar objects to find the differences.
If the document has multiple revisions, you can select which revision you want to select files from, this allows you to compare versions of a file between revisions.
The Object Comparison Plugin must be selected while deploying the website.
After installing Object comparison plugin you should be able to see the option in the task pane.
