02w. "Thermal Transient Analysis" (TTA) - AutoPIPE Load Case
Comments, Questions, and Answers about AutoPIPE TTA Analysis:
  1. Steps to perform a Thermal Transient Analysis (TTA)
  2. Calculated gradient uses what temperature for TTA Pipe & Insulation?
  3. Explain difference between ambient and room temperature
  4. Correct ambient temp for use with TTA analysis
  5. Quality of TTA results
  6. Is the through wall gradient analysis output (delta T1, delta T2, Ta and Tb) automatically accounted for in the flange design?
  7. Technical justification for ignoring Delta T2 variation whenever the maximum linear temp variation is negative
  8. TTA analyze for steam Pipeline
  9. Manually create and import a .TTP (Thermal Transient Profile) file
  10. Does TTA module calculate the heat transfer film coefficient for water using only the Dittus-Boelter method?
  11. Flow Fraction = 0.00
  12.
Loads and Load Sets
