| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Error |
| Date Logged & Current Version | March. 2018 11.02.00.10 |
The following appears when using AutoPIPE
Intel(r) Visual Fortran run-time error
forrtl: severe (24): end-of-file during read, unit 95, file C:\Users\MIKE~1.DAT\AppData\Local\Temp\AP_110300\1_4963\1.cii
Image PC Routine Line Source
libifcoremd.dll 0F6C91AA Unknown Unknown Unknown
Stack trace terminated abnormally.
OK
Why and how to avoid it?
Open the DAT file in a HexEditor. IF the file has no data in the first 20 lines, the file may have been incorrectly saved. Try opening the BAK file and save to a local folder. If unsuccessful, the file must be recreated.
Open the *.CII file with any text editing application ( Ultra edit, NotePad++, etc..), confirm file is not hexadecimal or other unreadable format.
A good *.CII file has readable text as imaged above (ex. Version, project, client, etc..)
AutoPIPE can only read a valid *.CII file.
1. Go back to source of *.CII file and ask that another file be recreate for review.
2. If file was send over email, confirm that sending or receiving company firewall did not affect the file.
Visual Fortran run-time error messages
