| Applies To | I&W; Layout Designer; Revision Control | ||
| Product(s): | |||
| Version(s): | |||
| Environment: | 08.11.09.140 | ||
| Area: | Document Revision;Security | ||
| Subarea: | |||
Cannot Revise I&W Drawings - You do not have Permission for this Task
Cause: This message is caused by the user's AutoPLANT Security login not having proper Application Access Rights.
Solution: Grant the user proper Application Access Configuration rights as outlined below:
Grant the following rights:
The Program Actions Revise Documents and Edit Properties are required
