| Product(s): | AutoPLANT P&ID | ||
| Version(s): | XM, V8i, V8 | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Artiom Jakubovic, Bentley Technical Support Group | ||
Usually this alert is shown upon opening P&ID export copy that was imported to project. In this case this alert informs that P&ID does not have any intelligent data. In cases when this alert is received upon opening P&ID model that was not imported, the following workflow could be used in order to resolve this issue.
