| Version(s): | Connect |
| Area: | Install |
| Date Logged & Current Version | Jan 2019 41.00.00.006 |
Note:
1. CLOSE ALL APPLICATIONS before starting this installation process.
2. Contact your IT department to be sure that there is no user restrictions for installing software on your computer system. If so, request IT assistance.
The Following procedures assumes:
1. Navigate to the downloaded file (ex. apvs41000006en.exe)
2. Double click on on the *.EXE to start the installation process.
The following are typical screen shots and responses for a default installation:
Press Next button
Read the EULA agreement enable the check box and then press Install button:
Press Yes button
It may take a few moments for the application to verify minimum requirements are met. If not, the missing windows applications are now being downloaded and installed
Press Next button
Update information on as needed on the 3 lines provided, and press Next button
Press Next button
Press Install button
It may take a few moments for the application to unzip and install the application.
Press Next button
Press Next button
Press Close button
The Readme file will soon appear. Suggest to review each hyperlink for detailed information about this new version.
A new dialog may appear off to the side, CONNECT Client Sign in. You must Sign in as this will have bearing on Licensing Bentley programs.
CONTINUE with Licensing AutoPIPE Vessel
Bentley Select Services Technical Support webpage:
