| Product(s): | AutoPLANT Modeler V8i |
| Version(s): | SS5 | SS6 | SS7 | SS8 |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | AutoPLANT Modeler [FAQ] |
| Subarea: | Supportability with OpenPlant Isometrics Manager |
| Original Author: | Keith Couvillion, Bentley Product Advantage Group |
Only AutoPLANT V8i SS5, SS6, SS7, SS8 project versions are supported when generating Isometrics from inside of the AutoPLANT Modeler application using Bentley® OpenPlant Isometrics Manager V8i SS5, SS6.
For any Pre-V8i SS5 version AutoPLANT project, user will have to follow below procedure:
AutoPLANT V8i SS8, SS7, SS6, SS5, SS4 and SS3 project versions are supported when generating Isometrics from outside of AutoPLANT Modeler. User will connect Bentley® OpenPlant Isometrics Manager V8i SS5, SS6 to the project and generate Isometrics directly through Bentley® OpenPlant Isometrics Manager V8i SS5, SS6.
Note that user will first have to enable the project to be usable with Bentley® OpenPlant Isometrics Manager V8i SS5. SS6. To achieve that, expand the project node in Bentley® Project Administrator, right-click at 'OpenPlant Isometrics' node and select 'Enable for OpenPlant'.
Once the above step has been done, the user can load the project in Bentley® OpenPlant Isometrics Manager V8i SS5, SS6 and generate the Isometrics directly.
