| Product(s): | AutoPLANT Modeler V8i |
| Version(s): | SS5 | SS6 | SS7 | SS8 |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | AutoPLANT Modeler [FAQ] |
| Subarea: | Supportability with ProjectWise |
| Original Author: | Keith Couvillion, Bentley Product Advantage Group |
ProjectWise V8i SS4 Refresh and ProjectWise V8i SS4 versions are supported with AutoPLANT SS5. However, in order to benefit from the enhancements implemented in AutoPLANT SS5, ProjectWise V8i SS4 Refresh will be required. The enhancements will not work when using ProjectWise V8i SS4 version with AutoPLANT SS5.
communities.bentley.com/.../bentley-autoplant
communities.bentley.com/.../autoplant-modeler-faq
