| Product(s): | AutoPIPE Vessel | ||
| Version(s): | CONNECT; | ||
| Area: | Uninstall | ||
| Date Logged & Current Version | May. 2016 40.01.00.09 |
How to uninstall AutoPIPE Vessel from my computer?
The best approach to uninstalling AutoPIPE Vessel from a computer is to use the procedure outlined below:
Note: video of these steps can be found at the bottom of this WIKI page.
Right-click the Start button and click Control Panel. Go to Programs and Features (if your Control Panel is in Category view, go to Uninstall a Program).
Open Control Panel>
Start Programs and Features>
Open Control Panel>
Start Add/Remove Programs>
After the applications has opened, a listing of all the programs installed on the computer are displayed. Uninstall the following programs if listed:
Note: best to order programs by Publisher (i.e. all Bentley applications will then be grouped together)
1. AutoPIPE Vessel
After theses applications have been uninstalled, delete the following folders if present:
1. C:\ProgramData\Bentley\AutoPIPE Vessel CONNECT
2. C:\Program Files (x86)\Bentley\
DONE, AutoPIPE Vessel has been removed from the computer.
Note: Your version may be different but the process is fairly similar.
Download, Installation, Uninstall - Bentley AutoPIPE Vessel
