Applies To | |||
Product(s): | eB Rendition Services | ||
Version(s): | 15.05.01, 16.x.x | ||
Environment: | N/A | ||
Area: | Interplot Components and eB | ||
Subarea: | N/A | ||
Original Author: | Bentley Technical Support Group | ||
The error below shows :
1) In eB Rendition queue when trying to render a drawing to a PDF file
2) In eB FTR queue when adding a drawing file to a class enabled for FTR
The error body is:
OPENBADFMT, Error opening "C:\Users\eb-srv-qa\AppData\Local\Temp\eB\eB_FTR_Service\{08C8C07C-9D8C-46C7-90DD-9F6C9F76555C}\177.dwg" - The file format is not supported. NOCREATE, did not create IPARM file Error HRESULT E_FAIL has been returned from a call to a COM component. Exception Stack Trace: { --- Begin of exception stack trace --- System.Exception: OPENBADFMT, Error opening "C:\Users\eb-srv-qa\AppData\Local\Temp\eB\eB_FTR_Service\{08C8C07C-9D8C-46C7-90DD-9F6C9F76555C}\177.dwg" - The file format is not supported. NOCREATE, did not create IPARM file ---> System.Runtime.InteropServices.COMException: Error HRESULT E_FAIL has been returned from a call to a COM component. at Iplotorg.IPlotSet.AddPlot(String bstrPlotName, String bstrInputFile, String bstrSettingsFile) at eB.Engine.InterPlotActivity.ConvertToPdf.Execute(NativeActivityContext context) --- End of inner exception stack trace --- at eB.Service.Ftr.QueueEventHandler.InvokeEngine(Int32 type, M3Xml xmlParams) at eB.Service.Ftr.QueueEventHandler.FtrFile(String workingDir, String cryGUID, Double fileId, Int32 ftrReposId, String m2Server, String xmlFtrInfo, QueuePayload& p) at eB.Service.Ftr.QueueEventHandler.ProcessFtr(Double jobId, String jobType, String workingDir, Double fileId, Int32 ftrReposId, String xmlFtrInfo, String m2Server, QueuePayload& p) at eB.Service.Ftr.QueueEventHandler.ProcessQueueEntry(Object sender, PollEventArgs e) --- End of exception stack trace --- } Inner Exception: Error HRESULT E_FAIL has been returned from a call to a COM component. Stack Trace: { --- Begin of exception stack trace --- System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component. at Iplotorg.IPlotSet.AddPlot(String bstrPlotName, String bstrInputFile, String bstrSettingsFile) at eB.Engine.InterPlotActivity.ConvertToPdf.Execute(NativeActivityContext context) --- End of exception stack trace --- } } }
The BentleyView version 8.11.09.303 installed with the Projectwise Interplot Server components is not the latest version of BentleyView. This causes later drawing versions not to be processed because they fail to load in BentleyView.
To fix this problem, go to SELECTServices and download the latest version of BentleyView 8.11.09.459 , and install it in the same server that runs Projectwise Interplot Server.
