| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | modeling |
| Date Logged & Current Version | Nov. 2020 12.04.00.13 |
How to model an offset drip pipe in AutoPIPE?
Simple, model the header leg on a segment. Be sure to model a node point at the location where the drip pipe will attach to the header pipe. Then create the drip piping as a new segment. Again, be sure insert a node point on the new segment adjacent to the location where the 2 pipes will be connected. Then connect the 2 segments together by using a connected anchor or beam between the 2 node points nearest the intersection point:
Example: connected anchor was added between A05 - B01. Optional - use a rigid beam between A01 - B01
Modeling Approaches, Tips, Techniques
