| Product(s): | AutoPLANT P&ID |
| Version(s): | |
| Environment: | |
| Area: | |
| Subarea: | |
| Original Author: | Dinesh Solanki, Bentley Product Advantage Group |
- Open Project Administrator>Databse>Databases>PROJDATA>Edit tables> Nozzle.
- Uncheck protected > Ok
- Click on Table Design> Add a new field NCODE
- Close the Database
- Now, in the same node in Project Administrator. Go to AT_VIEWS>AT_PID_NOZZLE>Edit>Nozzle fields and enable NCODE
- Open P&ID and Go to Annotation Tool.
- Now, select the component to Annotate i.e. Nozzle.
- Notice NCODE has been added in the vailable fields.
- Place the annotation
Note: For AutoPLANT Modeler SS5 NCODE field is ready there so skip steps 1 to 4.
Comments or Corrections?
