Modifying Color, Line Style and Line Weight of Piping and Components
 Product(s):OpenPlant Isometrics Manager
 Version(s):08.11.09.XXX
 Environment: Windows 7 64 bit
 Area: Settings/Attributes
 Subarea: -
 Original Author:Keith Couvillion, Bentley Technical Support Group
Symbology
The Component Placement section in the Configuration Manager controls the color, line style and line weight of piping and components in the drawing.
  1. Open Bentley Project Administrator V8i
  2. Select your project in the Browser Tree
  3. Click OpenPLANT Isometrics
  4. Click Settings
  5. Click Create/Modify
    This opens the OpenPLANT Configuration Manager
  6. Click the Isometrics Style tab
  7. Select the relevant style from the “Style” option button
  8. From the categories in the left pane, select “Component Placement”
  9. Change any of the symbology configuration options and click “Save”
Pipe Symbology
Use the steps below to set the symbology for pipe and bend components.
  1. Open the Isometrics Configuration tool
  2. From the Isometric Configuration dialog:
      1. Select the Isometrics Style tab
      2. Style – Select the relevant style from the dropdown
      3. Select Component Placement from the tree
      4. Pipe Symbology – Set the Line properties as required
      5. Click Save
Use the step below to change the level (layer) for pipe and bends.
  1. Select a level name from the drop down list
    OR
  2. Type a new level name in the text box. The new level will be added to the drawing during creation.
  3. Click Save
Continuation Symbology
Use the steps below to set the symbology for continuation components.
      4. Continuation Symbology – Set the Line properties as required
      5. Click Save
Existing Pipework Symbology
Use the steps below to set the symbology for existing components.
      4. Dotted Pipework Symbology – Set the Line properties as required
      5. Click Save
Failed Components Symbology
Sometimes components cannot be drawn in the iso. Most commonly this is due to a missing symbol in the cell library or an incorrect or missing mapping in the Supplemental Isometrics Isoextractor schema. The location of the failing components in the isometric drawing is indicated with a thick red circle. To change the symbology, set color, line style and line weight according to your preferences.
      4. Failed Cell Symbology – Set the Line properties as required
      5. Click Save
communities.bentley.com/.../12641.modifying-the-iso-content
Comments or Corrections?
