| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Install |
| Date Logged & Current Version | April 2019 12.00.00.14 |
How to install AutoPIPE's PCF translator after AutoPIPE has been installed?
Short answer, uninstall AutoPIPE and reinstall AutoPIPE using the instructions here.
AutoPIPE's PCF translator is a separate application outside of AutoPIPE. The program is installed based on the check box options user's enable during the installation process.
Issues with Importing *.NTL file
PCF Translator FAQ & troubleshooting
