Applies To | |||
Product(s): | AutoPLANT Piping | ||
Version(s): | 08.11.09.140 | ||
Environment: | Windows 7 32 bit, Windows 7 64 bit, Windows XP 32 bit, Windows XP 64 bit | ||
Area: | AutoCAD | ||
Subarea: | Settings | ||
Original Author: | Dinesh Solanki, Bentley Technical Support Group | ||
Often DXB file format is required.
Open the AutoPLANT model and from Menu bar select, File-->Menu-->Plotter Manager.
3. In the Add Plotter dialog ensure "My computer" is selected and proceed
4. On the Plotter Model page, under Manufacturers, select AutoCAD DXB File and Under Model,
select DXB File.
5. Choose Next.
6. Select Import PCP or PC2 page and import file-->Next
7. Enter the name of the plotter cfg file
8. Click, Finish
A new plotter configuration file (PC3) will be created.
