13. Settings Enhancements & Defects for AutoPIPE
Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Enhancement - 1112537:
File>Open reverts back to last folder instead of default location
TFS-E875283:
Remove "Include torsion in code stress" from output report when applicable code has not been selected
TFS-E565484:
Add option to assign horizontal Global axis designations
TFS-E187234:
Add feature to specify or report max. spacing of mass points per span
TFS-E138195:
Add option to enter acceleration due to gravity
TFS-E126889:
Consider axial force in selection of load pair for Max Range combination
TFS-E126888:
Add details to online help regarding selection of Max Range load cases.
TFS-E121889:
Save North Arrow directional settings with the model
TFS-75309:
Update "Use nominal thickness" default settings Load Menu: two menu items have same keyboard shortcut key
CAE-CR-8922
Add feature to assign Y-factor to pipe properties
Enhancements Requests and Logged Defects
