Applies To | |||
Product(s): | Bentley Navigator | ||
Version(s): | 08.11.08.43 | ||
Environment: | N\A | ||
Area: | General | ||
Subarea: | N\A | ||
Original Author: | Todd Cassell, Bentley Technical Support Group | ||
Translate wrapped text from Autocad to Navigator
User had claimed that after opening an Autocad drawing, that any wrapped text did not translate across to Navigator
Once upgraded, define the variable MS_DWG_DROPMULTILINEATTRIBUTE and give it a value of 1.
Save and exit. Then restart Navigator and this issue should be resolved.
