| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | Data |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
In a project environment, RATING value of spec reads 150LB, whereas at the time of placing the components in OpenPlant Modeler, it is taking the RATING as CL150 which conflicts the spec and their requirement.
It is happening because the RATING property on the PIPING_COMPONENT class is mapped with RATING_VALUE_MAP which contains the rating values as CL150, CL300, CL600..and so on.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../12009.component-openplant-modeler
