Why are all Dynamic results +ve (Positive) in AutoPIPE, how to get -ve (Negative)Dynamic results?
Product(s): AutoPIPE
Version(s): ALL;
Environment: N/A
Area: Results
Date Logged
& Current Version
March. 2017
11.00.00.22
Problem:
Why results for following load-cases are always +ve :
how to get -ve (Negative) results?
In short, in order to run a Dynamic Analysis one must first obtain the result from a Model Analysis. Note that calculated values from modal analysis are all +ve. Therefore the results for all dynamic analysis are +ve.
See AutoPIPE help
Help > Contents> Contents Tab> Reference Information> Results Interpretation> Dynamic Support Forces Results
Note: be sure to read the entire help page for clear understanding.
After reading the help reference above, to include a -ve (negative) dynamic load case (ex. SAM), create a user combination and set the scale factor to -1.00, as shown below.
Create additional User Code / Non Code combinations as needed to consider the -ve direction of dynamic load cases.
Dynamic Analysis
