| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | reports | ||
| Date Logged & Current Version | May 2015 09.06.02.06 |
What is the difference between the support and the restraint output reports? There seems to be some overlap.
Fro many years, AutoPIPE has had a Support and Restraint output report - yes there is some overlap
Support Report
Creates a sub-report section which lists support forces and displacements (local or global) for each active piping load. Anchor node points are not included in this report
Notes:
1. Rotation supports results are reported in this section, however, the Force column has a double meaning. For rotation supports only, the Force column means Moments with the units mentioned at the top of the report (ex. 75961 Ft-lb, not 75961 lbf)).
Restraint Report:
Creates a sub-report section which lists forces and moments at restrained points (ex. anchors and supports) for each active piping load.
Notes:
1. Results are always reported in the Global axis system
2. Moments are only reported for Anchors and Rotation type supports. All other support types will have moments = 0.00 because, anchors and rotation type supports are physically connected to the pipe to resist rotation type movement. For other supports, like a guide, the pipe is free to move / rotate freely but will be restrained when it comes into contact with the defined baring direction of a defined support.
For additional information, see the following AutoPIPE help section:
Help > Contents> Contents> Reference Information> Results Interpretation> :
"Restraint" Sub-report of the Output Report in AutoPIPE
