"Restraint" Sub-report of the Output Report in AutoPIPE
Comments,  Questions, and Answers for "Restraint" sub-report of the Output Report in AutoPIPE
1: Print a "max load" report for restraints
Answer:
Yes, after you create a new user defined non-code combination, under Tools> Model Options> Combinations> Non-Code Comb tab> where the combination method = ABS Max or Sign MAX, to evaluate up to 10 selected combination names at one time. .
2: When reviewing the load on a gaped restraint, there is a load in the same direction as a large gap. The pipe never closes the gap, so why is there a load on the restraint in that direction?
Answer:
If you are running a non-linear analysis, 9 times out of 10 time, the answer is due directly with Load sequencing. Please see the following WIKI page here
3: Gravity + Thermal + User load cases added together give incorrect Restraint Report results, why?
4: What is the difference between the Support and the Restraint output reports?
5: Which report should be provided to the Structural Engineer to size the anchor: the Support forces or Restraint Reactions report?
6: Restraint results do not appear to be changing with Temperature changes
Analysis Sub-reports FAQ
