03. How to view report for specific components in AutoPIPE Vessel?
Answer:
After the calculations are completed, make sure that the full calculation report is closed. Then go to the Geometry section at the bottom left of the screen and select the component and click on Show Selected Report Calculation Detail as shown below:
This should open only the report for the selected component.
To watch the on-demand webinar "Maximizing AutoPIPE Standard and Custom Reporting Capabilities", click here.
