| Product(s): | eB Rendition Services | ||
| Version(s): | 15.05.01, 16.x.x | ||
| Area: | Interplot Components and eB | ||
| Subarea: | N/A | ||
The error below shows :
1) In eB Rendition queue when trying to render a drawing to a PDF file
2) In eB FTR queue when adding a drawing file to a class enabled for FTR
The error body is:
Retrieving the COM class factory for component with CLSID {CAC2C26A-4215-11D0-98FB-08003601E054} failed due to the following error: 80080005 Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE)).
Exception Stack Trace:
--- Begin of exception stack trace ---
System.Runtime.InteropServices.COMException (0x80080005): Retrieving the COM class factory for component with CLSID {CAC2C26A-4215-11D0-98FB-08003601E054} failed due to the following error: 80080005 Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE)).
at eB.Service.Ftr.QueueEventHandler.InvokeEngine(Int32 type, M3Xml xmlParams)
at eB.Service.Ftr.QueueEventHandler.FtrFile(String workingDir, String cryGUID, Double fileId, Int32 ftrReposId, String m2Server, String xmlFtrInfo, QueuePayload& p)
at eB.Service.Ftr.QueueEventHandler.ProcessFtr(Double jobId, String jobType, String workingDir, Double fileId, Int32 ftrReposId, String xmlFtrInfo, String m2Server, QueuePayload& p)
at eB.Service.Ftr.QueueEventHandler.ProcessQueueEntry(Object sender, PollEventArgs e)
--- End of exception stack trace ---
Projectwise Interplot Organizer is used to generate the PDF renditions. The error is caused by one of the following:
1. Print Spooler is not enabled as a Windows Service. To fix enable and start the service
2. Set permissions for "Everyone" to "Full Control" on the spool directory if global access to the printer is the norm. Access to the spool directory can also be enabled on a user by user basis. The spool directory is normally located at C:\Windows\System32\spool
