| Version(s): | CONNECT Update 3, 10.03.00.30 | ||
| Area: | FAQ | ||
| Subarea: | N\A |
Behobene Probleme in MicroStation CONNECT Edition Update 3, 10.03.00.30
Dies ist eine Liste der gelösten Probleme für MicroStation CONNECT Update Edition 3, 10.03.00.30.
Sehen Sie dazu die untenstehende HTML Tabelle:
| Defekt Nummer | Beschreibung |
| 278368 | Resolved issue importing specific Land XML file. |
| 338780 | Resolved MicroStation crashes using re-associate dimension tool while element have been selected. |
| 349309 | Resolved a specific error when opening specific dwg files. |
| 389575 | Resolved issue where user cannot change and save Ref level symbology from Level Manager. |
| 478781 | Configuration variable values are trimmed at $ character. |
| 489722 | Resolved issue with zoom into Adobe PDF and shifts. |
| 491414 | Resolved issue with Match text attributes error in references. |
| 527097 | Unspecified error displays when trying to update parametric cell definition after grouping cell instances. |
| 527141 | Resolved Swiss GCS, transforming goes wrong for some elements. |
| 527144 | The icons for Multi-snap 1, 2 ,3 do not display in the message field. |
| 527277 | Resolved Multiline style does not update from dgn library. |
| 527282 | Resolved specific issue with Create Region tool using Flood option which resulted in incorrect regions created. |
| 527283 | Resolved specific case where "Create" cell bottom becomes grey out. |
| 527285 | Resolved create cell button is disable when using define origin first and selecting elements after. |
| 527401 | Resolved issue with terrain model import landxml keyin. |
| 527403 | Resolved error when opening a specific DGN file. |
| 527409 | Resolved printing animation to 3D PDF results in object being disconnected. |
| 527427 | Resolved false warning of Geometry exceeding SWA withTrim Solids Tool. |
| 527793 | Resolved digital signature fields are in the wrong location when a 3D reference file is attached to a 2D active. |
| 527808 | PDF Boundaries are not created properly from 2D master with 3D references with Transform. |
| 527816 | When Drawing Boundary is used, a "Print as 3D" (U3D) reference fails to rotate dynamically in Adobe Acrobat/Reader. |
| 527950 | Resolved Items with a 'Property Definition' name that contains spaces changes to '_WIP_CUSTOM_PROPERTY_'. |
| 527972 | Resolved error with copy/move parallel tool using options: Use active Attributes and make a copy. |
| 528029 | Resolved patternmap issue that wont wrap on solid elements properly if Units is Master and mapping = Cubic. |
| 528181 | Provide way to set custom ribbon group icon. |
| 528187 | Resolved shortcut when French (France) windows keyboard not working for "1" key. |
| 534674 | Resolved error with MicroStation while referencing specific Rhino files. |
| 535191 | Resolved issue with incomplete import of specific STEP files. |
| 560891 | Resolved Microstation error when importing specific RFA file. |
Hinweis: Die englischsprachige Liste der gelösten Probleme kann als PDF Datei direkt hier heruntergeladen werden.
MicroStation CONNECT Edition Update 3 - Announcement
Gelöste Probleme in CONNECT Edition Update 1
Gelöste Probleme in CONNECT Edition Update 2
Anderssprachige Quellen
| Original Author: | Yvonne Lohse |
