| Product(s): | AutoPIPE |
| Version(s): | CONNECT |
| Environment: | N/A |
| Area: | Technology Preview |
| Date Logged & Current Version | March. 2017 11.00.00.22 |
The Model Results Reports in Microsoft Word Technology Preview enables users to define custom reports and sub-reports that contain results in 4 categories: displacement, Support, Restraint, & Forces and Moments which is then exported to a Microsoft Word file that can be used to view, save, and/or print the report
The following are the limitations associated with this Technology Preview.
Currently limited to 4 sub-reports. When command is fully implemented into the program all remaining sub-reports will be added.
1. Select Results > Reports> Word Results Reports [Technology Preview] to display the Batch Report dialog.
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Bentley AutoPIPE> Command Reference> Results Group> Word Results report
Note: There is one known issue with using this Technology preview, the application will fail if using ASME B31.1 2010 and higher. This has been logged (Defect 800565) and to be fixed in a future versions of the application.
134341
241245
