| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 64 bit | ||
| Area: | OpenPlant Specification Generator | ||
| Subarea: | - | ||
| Original Author: | Rahul Kumar, Bentley Technical Support Group | ||
With AutoPLANT Plant design (PDW) spec data, conversion to OpenPlant Modeler spec, EC_CLASS_NAME field information missing. User was trying to use ‘Upgrade to OPM’ option but fails to populate the data each time.
During AutoPLANT PDW spec conversion, EC_CLASS_NAME field fails to populate the data. It was found that few fields MODULE_NAME & CLASS_NAME contains additional spaces which need to be taken care while converting specs. See image below.
To solve this issue, user either need to get the correct data with no spaces or manually trim the extra spaces present in each cell. Below steps illustrates removing the data and converting the specs successfully.
NOTE- If there is still an issue? User could create a Service Request and contact Bentley Technical Support group along with necessary data to get in depth analysis and for possible solution or workarounds or for filing Defects/Enhancements.
User could also see Help menu for Converting PDW data to OPM spec using multiple option. Some keywords would be ‘Open Exchange Spec’ OR Upgrade to OPM.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to the "Comments" area below. THANK YOU!
