| Product(s): | eB Web | ||
| Version(s): | 16.X.X | ||
| Area: | Internet Information Services (IIS) | ||
| Subarea: | |||
| Original Author: | Gintautas Bajoriunas, Bentley Technical Support Group | ||
This Wiki article will explain how to hide ASP.NET information in Response Header.
This can be tested by using Fiddler
To hide the version you need navigate to virtual directory, open web.config with text editor and add parameter enableversionheader="false" in httpruntime tag as in screenshot below
To hide information that your site is supported by ASP.NET in need to log on to your web server you need to open Internet Information Services (IIS) Manager and manually drop it from HTTP Response Headers (see screenshot below)
N/A
