Defect 1108054:
Wind Exposed Segments report listing does not list all affected segments
Enhancement 701160:
Update ASCE-7 wind code to 2016 edition
Defect 203815:
"All segments exposed to wind" checkbox on Wind dialog is not synchronized with the "Apply wind" checkbox of Segment tab
Enhancement 140470:
Add IBC 2009 to the wind profiles
Defect 139097:Tracker#:11097
Ground Elevation for Wind Dialog entered in Feet only for all input units
Enhancement 138668:
Increase height-pressure data pairs for the wind profile to 10 or more
Enhancement 138198:
Add option to set friction = 0 for non-linear analysis of Wind load cases
Enhancement 137103:
Add STAAD wind and seismic load generators
Enhancement 137023:
Add input grid for wind loading
Enhancement 109665:
Update ASCE-7 wind code to 2005 edition
Enhancements Requests and Logged Defects
