| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 64 bit | ||
| Area: | OpenPlant Specification Generator | ||
| Subarea: | - | ||
| Original Author: | Rahul Kumar, Bentley Technical Support Group | ||
In Specification Generator, requirement is to get automatic placement for a particular branched component under branch table.
With the use of Specification generator, Branch Table is being used to pick branch olet, Tees, couplings etc automatically. While modeling a branch user can opt for sepc grid to select multiple option. But there is a requirement to set priority for desired entry like Half coupling to pick automatically without choosing it from grids. Below steps will describe on how get it appeared inside the modeler.
See Help Menu for additional information.
How to Include Branch Code Inside Branch Table For Specification Generator in OpenPlant Modeler- http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/21094.how-to-include-branch-code-inside-branch-table-for-specification-generator-in-openplant-modeler
