| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Component | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Technical Support Group | ||
When we have multiple compatible joint types defined in schema then below dialog box is presented to user when making a connection.
As you can see the option for making selection a default joint is disabled by default. Follow the steps below to enable this option.
OPM_JOINTS_USE_DEFAULT_SELECTION=1
