Q. Why can't I choose a "Double Segmental" baffle type for a BFM heat exchanger?
Answer:
When there is a longitudinal baffle (Shell Type F) and if the baffle cut is horizontal, then it is not possible to set double baffle in the bundle.
It is possible to set Double Segmental type in changing the baffle cut type to vertical.
Shell and Tube Heat Exchangers
AutoPIPE Vessel
Bentley LEARN Server
