| | Applies To | | |
| | Product(s): | OpenPlant Modeler, OpenPlant Isometrics Manager, OpenPlant ModelServer | |
| | Version(s): | 08.11.09.440 | |
| | Environment: | N/A | |
| | Area: | Schema | |
| | Subarea: | | |
| | Original Author: | Rahul Kumar, Bentley Technical Support Group | |
After Upgrading to OpenPlant Modeler SS5 Refresh Release 08.11.09.440 users should also update their current schemas to include newly added features in 440 version. There have been some issues which got fixed in 440 release and some newly added property in schema which needs an update.
Below is the list of all schema changes between OpenPlant Modeler 08.11.09.404 and 08.11.09.440 versions.
Schema Changes
Changes done after 08.11.09.404 releases:
- OpenPlant.01.04.ecschema.xml.
- Added new classes for USER Catalog components.
- HVAC_CLEANING_ELBOW
- HVAC_SEGMENTED_CLEANING_ELBOW
- HVAC_OVAL_OFFSET
- Added property TRACING to class PIPING_COMPONENT.
- OPPID Compatibility:
- Fix for display labels for multiple classes.
- Added a new Relationship 'DOCUMENT_HAS_SIGNALLINE'
- OpenPlant_3D.01.04.ecschema.xml.
- New relationship added: DEVICE_HAS_NOTE.
- OPPID: Pump placement from spec support.
- Added Read_From_Spec property to SIDE_WALL_REGISTERS class.
- Additional updates for APM-OPIM instrument module and first part of Tubing module
- Mapping added for AutoPLANT Instrument Module.
- Added two properties to Joint Class to store connecting Ports GUIDs.
- Removed Properties P, H and Sequence from Piping Component and IL.
- Added TAPTYPE property to HVAC_TAKEOFF class.
- Added new classes HVAC_DOUBLEWALL_TO_SINGLEWALL_TRANSITION and HVAC_FIELD_CUT_ADAPTER for HVAC discipline.
- Added classes:
- HVAC_ROUND_COUPLING
- HVAC_OVAL_COUPLING
- TFS #104929. Added JOINTYPE property to HVAC_COUPLING
- HVAC_OVAL_OFFSET
- Added property DETAIL_SKETCH added to class DEVICE.
- D-130887: Designer information is not populated for support
- IL Customization Changes
- OpenPlant_3D_Supplemental_Modeling.01.04.ecschema.xml.
- Updated Parser regular expression for NAME property of support class.
- Added new custom attribute for OPM, using which we can retain certain properties after comparing another property of old and new components.
- Added catalog mapping for LENGTH property for HVAC_FLAT_OVAL_DUCT class.
- Removed Properties P,H and Sequence from Piping Component and IL
- EN: Added TAPTYPE property to HVAC_TAKEOFF class.
- Fix for Defect 104977: When using hookup command, most of the parts are placed as general parts. Doesn't use user parts.
- Fix for TFS #104977. Corrected values to allow correct queries.
- Added classes:
- HVAC_OVAL_OFFSET
- Defect 105869:VersionOne#: D-133108: Flowmeter is not available in Custom Piping Component Builder.
- Added new joint HVAC_MALEFEMALE_JOINT for User.
- Updated GEARBOX_OPERATOR CA to use GEARBOX_OPERATOR diagram from cell library.
- Designer information to be populated for supports
- OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.04.ecschema.xml.
- Enhancement 131229: APM-OPIM Instrument module: Defined new mappings for APM Instrument module.
- Enhancement 132280: APM-OPIM Tubing module mapping.
- Enhancement 131229:APM-OPIM Instrument module
- D-133133: Filler flange part ID shown twice in isometric
- D-130126: Blind flanges are double flagged
- OpenPlant_3D_Supplemental_Mapping_AutoPLANT.01.04.ecschema.xml.
- Additional updates for instrument module and first part of Tubing module; New mappings defined.
- Repair for TAP_CONNECTION error.
- Additional updates for instrument module and first part of Tubing module, New mappings.
- Swapping TAG and TAGNUMBER as data sources for EQUIPMENT_TAG and (NOZZLE) NUMBER.
- Added Property DETAIL_SKETCH added to class DEVICE.
- New mapping for TRACING
- Fix pipe nozzle (PDW) property mapping.
- OpenPlant_Supplemental_Tagging.01.04.ecschema.xml.
- Enhancement 93440: OPPID: Display label for Fluid Regulator in Tagging supplemental should change to not be child class Valve.
- Enhancement 77720: OPPID: Allow Data Differencing when syncing from/to the Project Database
- OpenPlant_3D_Supplemental_Imperial_DefaultValues.01.04.ecschema.xml.
- Added classes:
- HVAC_OVAL_OFFSET
- OpenPlant_3D_Supplemental_Information_3DComponent.01.04.ecschema.xml.
- Fix for Defect 104977: When using hookup command, most of the parts are placed as general parts. Doesn't use User parts.
- Added port information for User components.
- OpenPlant_3D_Supplemental_Metric_DefaultValues.01.04.ecschema.xml.
- Added classes:
- HVAC_OVAL_OFFSET
- OpenPlant_3D_Supplemental_MixMetric_DefaultValues.01.04.ecschema.xml.
- OpenPlant_3D_Supplemental_ModelingViews.01.04.ecschema.xml.
- Hide Connection type property for HVAC_COUPLING class.
- HVAC_OVAL_OFFSET
- IL customization changes.
- OpenPlant_CustomAttributes.08.11.ecschema.xml.
- Added OPOM custom attributes.
- Added a new custom attribute "IL_GRAPHICS_MAP" for IL Customization.
- PSDS Migration: Added new custom Attribute "PSDS_SNAP_POINT_INDEX_FOR_COMPONENT_ORIGIN" to allow users to customize the snap point they want to use as port less component's origin.
- OpenPlant_Supplemental_Units_Imperial.01.04.ecschema.xml.
- HVAC_OVAL_OFFSET
- OpenPlant_Supplemental_Units_Metric.01.04.ecschema.xml.
- HVAC_OVAL_OFFSET
- OpenPlant_3D_Supplemental_Model_Server.01.04.ecschema.xml.
- Set backward query depth to "1" for NAMED_ITEM
- OpenPlant_3D_Supplemental_Mapping_PSDS.01.04.ecschema.xml.
- PSDS Property Mapping for Associated Items.
OpenPlant Modeler
Comments or Corrections?
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to the "Comments" area below. THANK YOU!
