| Version(s): | 08.11.09.XXX |
| Environment: | Windows 7 64 bit |
| Area: | Component |
| Subarea: | |
| Original Author: | Harpreet Singh, Bentley Technical Support Group |
When we add elbows of multiple radius types (Long. Short, 3R) with same angle in AutoFittingRules.xml file it always pick the elbow for the class which is higher in the order. For example, we have two classes for 90 degree elbows of short radius type in AutoFittingRules.xml file it places the elbow which comes first in the order. This is because Auto Fitting does not give the user an option to choose from the multiple types of elbows defined in the spec or AutoFittingRules.xml file.
To overcome this user can define the new radius type for each elbow class which have same angle. Steps given below can be used to create new radius types.
OPM_AUTOFITTING_ELBOW_TYPES = Long Radius;Short Radius;3R;Sweep;
