| Product(s): | OpenPLANT Modeler | ||
| Version(s): | 08.11.09.462 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Component | ||
| Subarea: | |||
| Original Author: | Dinesh Solanki, Bentley Technical Support Group | ||
You might experience while HVAC placement for rectangular and oval ducts that centerline for ducts are not shown. Centerline representation of ducts is not done by default so in case you need to show centerline for ducts please check the steps below:
3. Now, begin placement of the ducts as shown below you will see the centerlines are placed.
Comments or Corrections?
