Note:
a. Update to Step #3 of the procedure:
3. Select Pump (Insert > Equipment > Rotating Equipment > Pump) command to open...
b. Update Step #4 of the procedure:
4. Run static analysis, and then select Output Report (Result > Quick Reports > Output Report) command to open the Batch...
Modeling Approaches in AutoPIPE
