| | Applies To | | |
| | Product(s): | OpenPlant Modeler, OpenPlant Isometrics Manager, OpenPlant ModelServer | |
| | Version(s): | 08.11.09.564 | |
| | Environment: | N/A | |
| | Area: | Schema | |
| | Subarea: | | |
| | Original Author: | Rahul Kumar, Bentley Technical Support Group | |
After Upgrading to OpenPlant Modeler v8i (SELECTseries5) Release 08.11.09.564 users should also update their current schemas to include newly added features in 564 version. There have been some issues which got fixed in 564 release and some newly added property in schema which needs an update.
Below is the list of all schema changes between OpenPlant Modeler 08.11.09.440 and 08.11.09.564 versions.
Schema Changes
Changes done after 08.11.09.440 releases:
Schema Updates:
Schema Version has been incremented to 01.06. Following outlines additional updates to schema:
OpenPlant.01.06.ecschema.xml
- Version update to 01.06.
- Made THICKNESS, WALL_THICKNESS and BEND_POINT_RADIUS uniformly type 'double ' everywhere
- STYLE should be of the type INT
- NUMBER_OF_PHASES should be INT.
OpenPlant_3D.01.06.ecschema.xml
- Addition classes for OpenPlant Support Engineering
- ObjectHasSupport for OpenPlant Support Engineering
- NOTE subclasses added for miscellaneous attachments
- Moved target class for AREA_HAS_NAMED_ITEM to be PLANT_BASE_OBJECT
- Replaced ELEMENT_BLOB with Geometry
- Added new NOTE child class 'ORIGIN_EQUIPMENT' which will be used to define custom origin for equipment.
- Added CUSTOM_ORIGIN_X, Y and Z properties to EQUIPMENT class.
- Display label of "Nut" changed to "Nut or Union Nut"
- New PULLED_TEE EC Class
- MACHINE_BOLT class added.
- New EC Properties for PLANT_BASE_OBJECT:
- CreateTime
- CreatedBy
- ModifyTime
- ModifiedBy
- New EC Properties for EQUIPMENT:
- CUSTOM_ORIGIN_X
- CUSTOM_ORIGIN_Y
- CUSTOM_ORIGIN_Z
- Associated Items List clean up.
OpenPlant_3D_Supplemental_Information_3DComponent.01.06.ecschema.xml
- Added HVAC Component Ports information
- PULLED_TEE port information
OpenPlant_3D_Supplemental_Mapping_AutoPLANT.01.06.ecschema.xml
- NOTE subclass added for miscellaneous attachments.
- BEND_POINT_RADIUS for MITERED_ELBOW is double.
- Mapping for AT_PLA_CHECK_FVBAL
- Mapping AT_SWGL_SAN_FLANGE to PIPE_ADAPTER
- AT_PC_FIELD_SUPPORT mapped to BASE support
- THICKNESS and WIDTH are now double type.
- NAME of DEVICE has been mapped to TAGNUMBER
- AT_PC_DIRECTIONAL_ANCHOR_PLATE mapped to DIRECTIONAL_PIPE_ANCHOR
- AT_PC_GUIDE mapped to DIRECTIONAL_PIPE_GUIDE
- NAME mapping removed for FASTENER
- SPECIFICATION mapped to SPEC for FASTENER
- FIRE_HYDRANT Class mapping
- FLOOR_OPENING Class mapping
- FOOT_VALVE mapped to AT_PLA_CHECK_FVBALL
- SPECIFICATION mapping for GASKET.
- AT_PLINE_THERMOWELL mapped to GAUGE
- GENERIC_BEND mapped to AT_DUCT_HYDRANT_FH1
- GENERIC_BRANCH mapped to AT_SEPARATOR_MOIS
- AT_DUCT_HYDRANT mapped to GENERIC_OFFSET
- AT_RING_GASKET mapped to GLAND
- AT_ATTACH_GRATEOPENING mapped to GRATE_OPENING
- AT_MEGA_FAST mapped to MECHANICAL_JOINT_KIT
- AT_SCARF mapped to MITERED_PIPE
- Removed mapping for ANGLE and BEND_POINT_RADIUS from MITERED_PIPE_BEND and updated mapping for MITER_CUTS.
- AT_ATTACH_REFDIM, AT_ATTACH_FLOOROPENING, AT_ATTACH_GRATEOPENING, AT_ATTACH_MATERIAL mapped to NOTE.
- For NOTE Class:
- LINENUMBER mapped to LINENUMBER
- NOTE_TYPE mapped to NOTE_TYPE_VALUE_MAP
- Removed mapping for REFPOINT_Z, REFERENCE_POINT_Z, REFPOINT_Y, REFERENCE_POINT_Y, REFPOINT_X, REFERENCE_POINT_X.
- NOTE_TYPE_VALUE_MAP EX Class added.
- Removed mapping for NUMBER and COMPONENT_NAME properties of NOZZLE.
- AT_SWGL_SAN_FLANGE mapped to PIPE_ADAPTER.
- Removed AT_SWGL_SAN_FLANGE mapping from PIPE_FLANGE.
- AT_FLANGE mapped to PIPE_FLANGE.
- PIPE_NOZZLE removed mapping for NUMBER Property.
- AT_COUP_OUTL72 mapped to PIPE_TEE.
- AT_GENERAL_WYE from BASE is mapped to PIPE_WYE.
- NAME and COMPONENT_NAME mapping removed for PIPING_COMPONENT.
- AT_ATTACH_REFDIM mapped to REFERENCE_DIMENSION.
- NAME property mapping removed for SEAL.
- AT_PC_SHOE mapped to Shoes.
- AT_PC_UBOLT mapped to STANDARD_UBOLT.
- AT_ATTACH_MATERIAL mapped to ADDITIONAL_MATERIAL.
- Removed COMPONENT_NAME mapping for SUPPORT.
- AT_SUPPORT_GBOLT mapped to UBOLT_ANCHOR.
- Removed AT_SUPPORT_GBOLT mapping from UBOLT_GUIDE.
- Removed DIMENSIONED_NOTE mapping to PROPERTY for WALL_PENETRATION.
- AT_SLIPON_WELD2 from plastic module mapped to WELD.
- Removed mapping for NUMBER property for WELD class.
OpenPlant_3D_Supplemental_Mapping_PDS.01.06.ecschema.xml
OpenPlant_3D_Supplemental_Mapping_PSDS.01.06.ecschema.xml
- NOMINAL_DIAMETER, BEND_POINT_RADIUS is now double everywhere.
- LINENUMBER is mapped to LINENO for NOTE EC Class.
- NAME mapped updated for RESERVED_AREA_PAR
- For VALVE_STAGE_TYPE Class, TWO_PORT_ELBOW and TWO_PORT_STRAIGHT EC properties mapping updated.
OpenPlant_3D_Supplemental_Mapping_SPMM.01.06.ecschema.xml
OpenPlant_3D_Supplemental_Model_Server.01.04.ecschema.xml
OpenPlant_3D_Supplemental_Model_Server.01.06.ecschema.xml
OpenPlant_3D_Supplemental_Modeling.01.06.ecschema.xml
- IsGraphical CREATION_ATTRIBUTE added to AREA_CLASS, STRAINER, INLINE_VALVE and NOZZLE classes.
- WIDTH and THICKNESS is now double everywhere.
- NUMBER_OF_PHASES is now of type INT for EQUIPMENT.
- STATE property EC Expression updated for FASTENER.
- New script references added for LUG_JOINT.
- New WAFERED_LUG_JOINT joint added.
- LAP_JOINT_STUB_END now uses InlinePlacementTool.
- BEND_POINT_RADIUS is now of type double for MITERED_PIPE_BEND class.
- EC Expression updated from 3R to 3.
- STYLE EC Property for PIPE_S_BEND is now string.
- PULLED_TEE mappings defined.
- STATE EC Property EC Expression is now defined.
- NOMINAL_DIAMETER is now of type double for VALVE_OPERATING_DEVICE.
OpenPlant_Catalogue.01.06.ecschema.xml
- SPMM_CATALOGUE_TABLE class added.
- SPMM_COMPONENT_TABLE class added.
- Added following classes:
- _45DegElbow
- _45DegLRElbow
- _90DegElbow
- _90DegLRElbow
- _BlindFlange
- _Cap
- _CAPBV
- _CheckValve
- _CheckValve_Fem
- _ConcentricReducer
- _ConcentricSwage
- _Coupling
- _EccentricReducer
- _EccentricSwage
- _GateValve
- _GateValve_Asym
- _GlobeValve
- _GlobeValve_Asym
- _Nipple
- _OrificeFlange
- _PipeStock
- _Plug
- _ReducingInsert
- _ReducingTee
- _SocketweldFlange
- _Sockolet
- _T
- _Tee
- _Thredolet
- _TRB
- _Union
- _WaferCheckValve
- _WeldNeckFlange
- _Weldolet
- STYLE is now string type for PIPE_PSBN class.
OpenPlant_Catalogue_Supplemental_Mapping_AutoPLANT.01.06.ecschema.xml
OpenPlant_Catalogue_Supplemental_Mapping_Modeling.01.06.ecschema.xml
OpenPlant_Catalogue_Supplemental_Mapping_PDS.01.06.ecschema.xml
OpenPlant_Catalogue_Supplemental_Mapping_PSDS.01.06.ecschema.xml
OpenPlant_Catalogue_Supplemental_Mapping_SPMM.01.06.ecschema.xml
OpenPlant_CustomAttributes.08.11.ecschema.xml
- Removed class MODELSERVER_CLASS_MAP.
- Redesigned class MODELSERVER_RELATIONSHIP_MAP.
- Added class MODELSERVER_UI_CUSTOMIZATION.
- Added class OPM_2D3D_CLASS_MAP
- Added class MODELING_FRAMEWORK_DEFINITION.
- Added classes for SPMM:
- SPMM_3D_Catalogue_AttributeProperties
- SPMM_3D_Catalogue_Class_Map_Struct
- SPMM_3D_Catalogue_ClassProperties
- SPMM_3D_Catalogue_PortAttributeProperties
- SPMM_3D_Catalogue_TableProperties
- SPMM_3D_Catalogue_ValueProperties
OpenPlant_ProjectProperties.01.06.ecschema.xml
OpenPlant_Supplemental_Tagging.01.06.ecschema.xml
OpenPlant_Supplemental_Units_Imperial.01.06.ecschema.xml
- UnitSpecification defined for LENGTH_SHORT.
OpenPlant_Supplemental_Units_Metric.01.06.ecschema.xml
OpenPlant_Supplemental_Units_MixMetric.01.06.ecschema.xml
OpenPlant_3D_Supplemental_Imperial_DefaultValues.01.06.ecschema.xml
- NUMBER_OF_PHASES is now INT for FAN_POWER_UNIT class.
- BEND_POINT_RADIUS is now double type for MITERED_PIPE_BEND Class
OpenPlant_3D_Supplemental_Metric_DefaultValues.01.06.ecschema.xml
OpenPlant_3D_Supplemental_MixMetric_DefaultValues.01.06.ecschema.xml
- BEND_POINT_RADIUS is now double type for MITERED_PIPE_BEND Class.
OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.06.ecschema.xml
- New mapping for FIRE_HYDRANT, FLOOR_OPENING, FOOT_VALVE, GRATE_OPENING, INSUL, NUT and GENERIC_BEND classes.
- ECX_IE_ITEMCODE updated for GENERIC_INSTRUMENT.
- SPECIFIC_BOM_LABELS custom attribute applied to NOTE class.
- New relationship ObjectHasSupport mapped.
- PipingSupport class mapping. (OpenPlant Support Engineering supports)
- IE_CMP_NAME and IE_DESCRIPT updated for PLANT_BASE_OBJECT.
- PULLED_TEE mapping defined.
- Value map updated for STANDARD_UBOLT, UBOLT_ANCHOR and UBOLT_GUIDE.
- ECX_IE_ITEMCODE updated for SUPPORT class.
- ECX_IE_ITEMCODE updated for TAP_CONNECTION.
OpenPlant_3D_Supplemental_ModelingViews.01.06.ecschema.xml
- ELEMENT_BLOB EC property mapping removed.
- ECArrayProperty Geometry mapping added.
- THICKNESS, BEND_POINT_RADIUS, WALL_THICKNESS, NOMINAL_DIAMETER and WIDTH are now double everywhere.
- STYLE is now of type string for PIPE_S_BEND.
- CreateTime, CreatedBy, ModifyTime and ModifiedBy are new properties. Updated their display info
- ACCESSORIES_LIST is ECArrayProperty for VESSEL.
OpenPlant_3D_Supplemental_Units_PDS.01.06.ecschema.xml
OpenPlant_IsoExtractor_Custom_Attributes.01.06.ecschema.xml
OpenPlant_Supplemental_ConsistencyChecker.01.06.ecschema.xml
- 2D3D Integration updates and new mappings.
OpenPlant Modeler
Comments or Corrections?
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to the "Comments" area below. THANK YOU!
