| Product(s): | OpenPlant Modeler | OpenPlant Isometrics Manger | OpenPlant Model Server |
| Version(s): | 08.11.09.564 & above |
| Environment: | - |
| Area: | Workspace |
| Subarea: | Update |
| Original Author: | Bentley Product Advantage Group |
To check new updates between OpenPlant module version 08.11.09.440 & 08.11.09.564. Below information list the files information which has been modified and newly added ones. This will aid user to check their workspace settings and confirmation. This will various files and folders mentioned for OpenPlant Modeler and OpenPlant Isometrics Manager.
Files Modified
%Workspace%\OPModeler
TopWorksPreview.cel
%workspace%\OPModeler\cells\TopWorksPreview.cel
- Gearbox Operator representation updated.
- Updated image of DIAPHRAGM_GEAR_OPERATOR
MatchOptions.xml
%workspace%\OPModeler\System\MatchOptions.xml
- Updated AutoMatch to include Matched properties in query. This gives an option to user to control if a certain match property should be included in spec query or not.
%workspace%\Projects\%project%
lisocomp.cel
%workspace%\Projects\%project%\Dataset\Isometrics\styles\As-Built\cell\lisocomp.cel
- To Implement Pulled Tee in OpenPlant Isometrics Manager
scaler.ini
%workspace%\Projects\%project%\Dataset\Isometrics\styles\As-Built\config\scaler.ini
style.cfg
%workspace%\Projects\%project%\Dataset\Isometrics\styles\As-Built\config\style.cfg
- Removed Slope symbol options.
- Options for numbering sequence for spools, welds and pipe cuts
- Compress Weld
style.xml
%workspace%\Projects\%project%\Dataset\Isometrics\styles\As-Built\config\style.xml
- Sloping Pipeline Indication Method – Rise & Run/Inch
- Name of NOTE label with variable shape changed to "Variable Shape Note Label"
- Added an option not to dimension a field weld
- Added user label configuration for misc attachment NOTE types.
- User labels inside component cell (instrument bubble)
IsoProj.cfg
%workspace%\Projects\%project%\Dataset\Isometrics\IsoProj.cfg
- OpenPlant Isometrics Manager Query capability (extended drawing attributes)
- Correct folders co be created after publishing the Iso to ProjectWise.
- Changed default value for 'PW_DATE_STORAGE_FOLDER_FORMAT' variable to 'ddMMyyyy'
- Isometric output in DWG format as a 2D flat file
- Removed OPIM_IMODEL_DIRECTORY config variable
OPM Lookup.mdb
%workspace%\Projects\%project%\Dataset\Mapping Databases\OPM Lookup.mdb
- Added New fields which were added to FLOWMETER table :
- MTR_L, MTR_H,
- MTR_W,
- INST_L, INST_H,
- INST_W, CONN_PORT_DIAM,
- CONN_PORT_LEN
JOINT.backward.ecquery.xml
%workspace%\Projects\%project%\Dataset\ModelServer\JOINT.backward.ecquery.xml
- Static Query updates for OpenPlant Model Server.
PIPING_NETWORK_SYSTEM.ecquery.xml
%workspace%\Projects\%project%\Dataset\ModelServer\PIPING_NETWORK_SYSTEM.ecquery.xml
SERVICE.ecquery.xml
%workspace%\Projects\%project%\Dataset\ModelServer\SERVICE.ecquery.xml
UNIT.ecquery.xml
%workspace%\Projects\%project%\Dataset\ModelServer\UNIT.ecquery.xml
reports.ecinstance.xml
%workspace%\Projects\%project%\Dataset\Reports\ReportDefinition_opm\reports.ecinstance.xml
- Updates for OpenPlant Model Server.
- Schema Version updates
Compression.mdb
%workspace%\Projects\%project%\Dataset\Specs Databases\Compression.mdb
- set blank value for:
- SCHEDULE
- RATING
- TAG
- MATERIAL
- MANU_FACT
OPModeler_Imperial.pcf
%workspace%\Projects\OPModeler_Imperial.pcf
- Schema Version update from 01.04 to 01.06
- OpenPlant Reporting to use same reports as OpenPlant Modeler
- New configuration Variable:
- OPM_AUTO_MATCH_PROPERTIES_FOR_REPLACE
- OPM_CUSTOM_MATCH_PROPERTIES_FOR_REPLACE
- OPM_CUSTOM_WAFER_TYPE_END_PREPS
- OPM_CUSTOM_FLANGE_TYPE_END_PREPS
- OPM_CUSTOM_WELD_TYPE_END_PREPS
- OPM_REPAIR_JOINTS_ON_ATTACH
- OPM_PIPELINEMANAGER_INCLUDE_REFERENCED
- OPM_UPGRADE_OLD_SCHEMA_PATHS
- OPM_UPGRADE_OLD_SCHEMA_VER_MAJOR
- OPM_UPGRADE_OLD_SCHEMA_VER_MINOR
- OPM_UPGRADE_MODIFIED_MAP
OPModeler_Metric.pcf
%workspace%\Projects\OPModeler_Metric.pcf
OPModeler_MMetric.pcf
%workspace%\Projects\OPModeler_MMetric.pcf
PDx_baytown.pcf
%workspace%\Projects\PDx_baytown.pcf
PSDS_Imperial_sample.pcf
%workspace%\Projects\PSDS_Imperial_sample.pcf
OpenPlant.RuleSet.xml
%workspace%\System\data\RuleTemplates\SuppressClashes\OpenPlant\OpenPlant.RuleSet.xml
- Schema Version 01.06 support added.
UnicodeDescriptions.dat
%workspace%\System\data\UnicodeDescriptions.dat
Files Added
%workspace%\OPModeler\schemas\DesignSync.01.01.ecschema.xml
%workspace%\OPModeler\schemas\IntegratedStructuralModel.04.00.ecschema.xml
%workspace%\Projects\%project%\Dataset\Dgnlibs\ExportSeed.dgnlib
%workspace%\Projects\%project%\Dataset\Dgnlibs\SmcImperial.dgnlib
%workspace%\Projects\%project%\Dataset\Isometrics\styles\%style%\config\dwgdata\DwgDisplayColors.tbl
%workspace%\Projects\%project%\Dataset\Isometrics\styles\%style%\config\dwgdata\DwgPlotColors.tbl
%workspace%\Projects\%project%\Dataset\Isometrics\styles\%style%\config\dwgdata\DwgSettings.rsc
%workspace%\Projects\%project%\Dataset\Isometrics\styles\%style%\config\dwgdata\MstnShxFileList.csv
%workspace%\Projects\%project%\Dataset\Isometrics\styles\%style%\config\dwgdata\opim.csv
%workspace%\Projects\%project%\Dataset\Isometrics\styles\%style%\config\dwgdata\opim.dws
%workspace%\Projects\%project%\Dataset\Isometrics\styles\%style%\config\dwgdata\opimseed.dwg
%workspace%\Projects\%project%\Dataset\ModelServer\AnyRoot.ecquery.xml
%workspace%\Projects\%project%\Dataset\ModelServer\AREA_CLASS.ecquery.xml
%workspace%\Projects\%project%\Dataset\ModelServer\EQUIPMENT.ecquery.xml
%workspace%\Projects\%project%\Dataset\ModelServer\PIPING_COMPONENT.backward.ecquery.xml
%workspace%\Projects\%project%\Dataset\ModelServer\PLANT_AREA.ecquery.xml
%workspace%\System\data\RSSFeeds.xml
%workspace%\System\data\RssManifestSeed.xml
communities.bentley.com/.../23345.schema-changes-between-openplant-modeler-version-08-11-09-440-and-08-11-09-564-new-releases
Comments or Corrections?
