04. Confirm the license change
Product(s):AutoPIPE Vessel
Version(s):ALL
Area:Licensing
Date Logged
& Current Version
May 2019
41.01.00.005
Problem:
The following appears when changing licensing settings:
why?
This is a written WARNING for the user has made a request to physically change the license settings from the current configuration to a new configuration. The user is urged to contact their Bentley On-site Admin to confirm that this is OK.
Note, if the user presses Yes, the account will now be liable for any over usage charges that may occur. Again, strongly advised to contact your Bentley On-site Admin for directions before making any changes to licensing. This dialog will always pop up when making a licensing change from the original setting to avoid any misunderstandings that a user was not forwarned. .
AutoPIPE Vessel
Bentley LEARN Server
