Error Code 032768 - Program has encountered an error and will close now
Product(s):AutoPIPE Vessel
Version(s):ALL
Area:Message
Date Logged
& Current Version
July 2020
41.05.00.008
Problem:
The following appeared when installing AutoPIPE Vessel
AutoPIPE Vessel Setup
I[Error:032768] Program has encountered an error and will close now
to recover from this condition. Running the program again will apply
the license changes as desired. If this problem persists, please
contact Bentley technical support
OK
Why and how to fix it?
The issue may be related to your network firewall or proxy server that could be blocking the CONNECTION Client from accessing ims.bentley.com and buddi.bentley.com.
There's a list of domains that the CONNECTION Client needs to access in order to sign in and activate your SES applications. The list in the following wiki here.
Recommend to contact your internal IT to ask that you're allowed to access those domains.
AutoPIPE Vessel
Bentley LEARN Server
