| Version(s): | ALL |
| Area: | Error |
| Date Logged & Current Version | June 2018 40.06.00.07 |
The following message appears when using AutoPIPE Vessel,
425 FLOATING HEAD (split ring/splices): insufficient thickness or gap not maintained.
why and how to avoid?
The gap in the blue rectangle is not maintained. The dimension T1 must be increased to remove the error.
Or, the input value [T1] must be removed, the program will calculate the correct value:
This is due to a condition of TEMA RCB-5.141 which is clearly printed out in the report:
Figure of TEMA RCB 5.141:
