| Applies To | ||
| Product(s): | OpenPlant Modeler | |
| Version(s): | 08.11.09.564 (SS5) | 08.11.11.XXX (SS6) | |
| Environment: | Windows 7/8.1/10 (64 bit) | |
| Area: | Properties | |
| Subarea: | ||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
In OpenPlant Modeler, when a joint is recreated/fixed bolts and gaskets tend to inherit the properties from active pipeline in standard preferences dialog. For example, it inherits the properties like Unit, Service, Specification etc. from the active pipeline rather than the connected components.
Adding Variable in Managed Project in ProjectWise
Now again connect the flanges together and check the properties of gasket in the element info dialog.
As you can see the gasket is now inheriting the service, unit and specification from adjacent components rather than active pipeline.
