| Version(s): | ALL |
| Area: | |
| Date Logged & Current Version | June 2018 40.06.00.07 |
Lifting lugs modeled and shown on 3d model but no calculation results in AutoPIPE Vessel reports, why?
Lifting lugs are designed only when a Lifting case is requested, check the box in the "Design Parameters" Dialog.
