| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.564 | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Component | ||
| Subarea: | Graphics | ||
| Original Author: | Rahul Kumar, Bentley Technical Support Group | ||
In OpenPlant Modeler, to highlight components based on Shop or Field Value.
User requirement was to highlight or check components based on Shop or Field value in model for inspection purpose. Below steps will describe one method to check the components based on the property value.
