Technology Preview
Features listed here are considered as a Technical Preview and should not be used for commercial work. Please use this feature and provide Bentley with feedback in order to have this feature work in the manner your team needs.
List of Technology Previews first available in:
AutoPIPE Vessel 40.07.00.007:
1.
AutoPIPE Vessel 40.06.00.07:
1. Expansion joint design Finite Element Analysis (FEA) calculation based on TEMA 9th edition, for expansion joint spring stiffness calculation, available on 64-bit OS only
AutoPIPE Vessel 40.02.00.08:
1. CONNECT Project Configuration Settings (to manage project level settings through CONNECT)
2. Chinese pressure vessel design code, GB-150
