| Version(s): | All |
| Environment: | N/A |
| Area: | Customize |
| Date Logged & Current Version | Nov. 2016 40.02.00.08 |
What drawing and report templates are available in AutoPIPE Vessel?
Answer:
The following files can be modified by the user as needed.
a. By default, Report template files are in the following folder:
C:\Users\Public\Documents\AutoPIPE Vessel_version\Config\Report
b. By default, Drawing template files are in the following folder:
C:\Users\Public\Documents\AutoPIPE Vessel_version\Config\Cad
