Applies To | |||
Product(s): | Exor TMA | ||
Version(s): | N/A | ||
Environment: | N/A | ||
Area: | N/A | ||
Subarea: | N/A | ||
Original Author: | Bentley Technical Support Group | ||
User encounters this error when performing a TMA upgrade, at the Apex stage:
APPLICATION 101 - TMA Reports
Set Credentials...
Check Compatibility...
API Last Extended:20090112
Your Current Version:20090112
This import is compatible with version: 20090112
COMPATIBLE (You should be able to run this import without issues.)
Set Application ID...
Declare
ERROR at line 1:
ORA-20001: Package variable g_security_group_id must be set.
ORA-06512: at "APEX_030200.WWV_FLOW_API", line 48
ORA-06512: at "APEX_030200.WWV_FLOW_API", line 246
ORA-06512: at line 16
Replication Steps: Perform TMA upgrade after taking copy of database.
Usually this is because the copy of the database has been installed on a machine where Apex hasn't been installed yet, or the IM4 workspace is missing. Instructions for doing these are in the install guides.
