| Version(s): | 08.11.09.459 | ||
| Area: | Raster Manager | ||
| Subarea: | N/A | ||
| Original Author: | Frank McAllister, Bentley Technical Support Group | ||
I am attaching a TIF raster image to my DWG design file and it does not stay attached. I attach the TIF image in Raster Manager and it displays. If I do File > Save in MicroStation or I exit the DWG file in MicroStation my TIF image is detached.
When user created his TIF images he was putting spaces in the TIF image file name.
User was creating TIF image using the file name TCP 2 .tif. Had user to rename his TIF image to tcp2.tif so there were no spaces in the file name. User was then able to attach his TIF image and the TIF image would stay attached. The raster image not staying attached only happens with AutoCAD DWG design files. It does not happen with DGN design files.
