| Version(en): | 08.11.09.833 | ||
| Umgebung: | N\A | ||
| Produktbereich: | Basisgeometrie | ||
Wenn ein Tool ausgewählt wird, wird die Ikone nicht hervorgehoben.
There are a number of reasons why this may occur, and the options to resolve this issue are as follows:
-Ensure that the Element Highlight Color is set to a colour that will display:
Settings>Design File>Design File Settings>Color Highlight colour is set to magenta.
-Ensure that Identify Elements Automatically setting is checked in Accusnap
-Ensure Pop-up Info is enabled or disabled through AccuSnap Settings.
-The following setting may need to be enabled:
Workspace > Preference > Input Turn On the "Allow ESC key to stop current command"
then "OK" Save Settings.
The command will then remain highlighted until ESC is selected.
XXXXXXX(Add more links as needed for other relevant Be Communities content.)XXXXXXX
