| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | modeling | ||
| Subarea: | |||
| Date Logged & Current Version | Aug. 2015 33.02.02.04 | ||
Local loads due to a nozzle in WRC 107/297: Why is the weld joint efficiency equal to 1 in AutoPIPE Vessel?
Basically, the WRC 107/297 ignores the stresses due to the internal or external pressure.
AutoPIPE Vessel considers the stresses due to the pressure and uses a weld joint efficiency equal to 1 in reference of the UG-37 where the thicknesses due to the pressure are calculated for the opening reinforcement equal to 1.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
